Low Voltage error and no start
pcmpetepcmpete Member Posts: 114 ✭✭
edited November 2021 in Engine Discussions
Twin 377s with DTS & Axius
Both engines started fine.
Ran for approx. 1 hour
Dropped anchor for 30mins.
Starboard engine started fine.
Port engine - as soon as I turn key to on I get a 'Low Voltage' on my VV.
No sounds from the starter when trying to start.
I tried the Emergency battery combine switch, same result.
Ran the genny for 30mins to charge all batteries, still nothing.
I tested the Port starting battery voltage after a short rest from charging an got 12.6v, still no start.
Where/what should I check next?
Thanks guys
    Connections on batterie switch
  • LaReaLaRea Member, Moderator Posts: 8,001 mod
    What he said ... check all of the small wires connected to your batteries.  Check for loose terminal nuts, and also for faulty connectors (12V and ground).  DTS needs a solid power feed from the battery.
    Check the battery breaker in the switch location. Make sure it isn’t tripped and the connection is good.
  • pcmpetepcmpete Member Posts: 114 ✭✭
    Is the VesselView/Smartcraft powered by the 'Clean Power' or Battery main cable via the starter then engine harness?
    Each DTS module at the helm has a 40-amp power cable direct from a starter battery, with an inline fuse.
    Is that different from the ‘clean power’?   I haven’t found any fuses behind the helm.  I just have accessory relays.  Do you have a photo of the 40amp fuses so I know what to look for.  Thanks
  • YYZRCYYZRC Member Posts: 5,367 ✭✭✭✭✭
    I had a nut come loose on my stern port side breaker panel which had the VV reading only 11 volts. I don’t have DTS so the boat started fine but I kept getting alarms.
    That breaker panel is only thing I have never checked since owning the boat.  Did you find any corrosion in there or just a loose connection?   Thanks
    I found several loose connections actually! No corrosion but I am in fresh water.
