Mercruiser DTS
bandk
Member Posts: 9 ✭
Has anyone have the "1 Stick" function on the DTS stop working, The yellow light comes on when the button is pushed, but the light does not go red to indicate the syncing of the engines. The engines will sync up with the dual throttles at a higher rpm. 350 with twin 5.7s/B3 out drives. Thanks
To be honest, it seems like a useless function. DTS will sync the engines automatically, so the button-pushing needed for 1-stick operation seems like wasted effort. I just grab both throttle handles and go.
Did it stop working suddenly, or was it always that way - like a programming issue?
Here are the instructions from the manual:
(SINGLE) LEVER
The Axius system features the ability to command both engines with a single lever. This feature simplifies engine management during rough sea conditions by allowing you to grasp a single lever to command both engines simultaneously.
To engage 1 (single) lever mode:
1. Place both ERC levers in neutral.
2. Press the "1 LEVER" button located on the DTS Trackpad attached to the ERC levers.
3. The "1 LEVER" button lights.
4. Place the starboard ERC lever into gear.
5. The engine RPM raises and lowers simultaneously while the transmissions remain in the same gear.
To disengage 1 (single) lever mode:
2. Press the "1 LEVER" button. The "1 LEVER" button light turns off.
SYNC
The Axius system features Sync, an automatic engine synchronization feature, which engages automatically at key‑up. Sync monitors the position of both levers. If both levers are within 10% of one another, the port engine synchronizes to the starboard engine's RPM. The smartcraft system will automatically disengage Sync at the last 10% of lever range to allow each engine the ability to reach maximum available RPM. Sync cannot engage until its minimum RPM is met.
One lever works great - also like the combined trim/tilt feature.
Really nice when someone else is piloting the boat & they are used to single lever controls. (ie: wife while I'm having a squirt in the head)
@bandk double check with the DTS manual...you may have inadvertently changed some control settings. That is when the red lights show up.
