Bottom coat
rasburyrasbury Member Posts: 8,654 ✭✭✭✭✭
I'm putting our boat in a local marina for a month...300 bucks with power...not the point...100% fresh water with no bottom paint...am I ok?
    Yea except it will be a nasty project to clean the bottom after one month. I kept my 310 in the water for a summer with no bottom paint. I had it pulled every 6 weeks and I cleaned the bottom. Was a horrible couple of hours using zep toilet bowl cleaner but it was clean as new when it went back in.
  • YYZRCYYZRC Member Posts: 5,344 ✭✭✭✭✭
    My boat has no bottom paint and sat in freshwater for almost 6 months. Cleaned up the bottom in no time with zero effort with Starbrite Hull Cleaner Spray Gel. Not cheap but worked awesome.
  • rasburyrasbury Member Posts: 8,654 ✭✭✭✭✭
    That's what I'm thinking.  The river is dark because of cypress trees.  The far north of the st johns is brackish bit I'm more at the headwaters so it is all spring fed clean water. Heck, you all might be drinking it as it is bottled and sold from this area .  . So if you taste a little rinker in your mouth it was me!
    What does Rinker taste like? I imagine it tastes like bad wiring and upholstery foam.
    Just keep in mind you are in WAAAAAY warmer water than any of us and growth loves warm water. My bottom would get nastier in August than in June.
  • MarkBMarkB Member Posts: 3,992 ✭✭✭✭✭
    Depends on who's boat. @javhav I'm sure his boat taste like champagne and perfume!
  • Aqua_AuraAqua_Aura Member Posts: 2,681 ✭✭✭✭✭
    I have no bottom coat and I won't even begin to tell you how long my boat has been in the water. You shouldn't worry at all for that short of time.
    If your using it, just anchor near a sandbar every once in a while, get in the water and brush the bottom.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,792 mod
    Yep, I could see Ras, just rest the brush on that big log in the water to take a break too. :smile:  Oh, it was an alligator!!
    edited December 2021
    It can get pretty cool February and March..not a lot of deep water so it reacts to Temps too...and the gators get lazy.
