Fuel sender issue
ams
Member Posts: 3 ✭
Hi, Fuel sender issue - I have a 2002 180BR with 23gal Florida Marine fuel tank. The sender (float arm type) has stopped working (gauge and wiring ok) and would like to replace with pole type - how do i find out the resistance range of the sender for the replacement?
with thanks
be aware: the five bolt fittings only fit on the tank one way, it is a smart plan to adhere the cork (make sure it's cork) gasket to the sender/basket mating surface before trying to attach it to the tank.. otherwise, it can become a maddening process quickly. :-)
