Does your larger Rinker cruiser have non-compliant nav lights?
I just realized that my 370 has illegal nav lights. I'm wondering how many others (370, 390, 400, 410, 420) might be the same.
The main problem is that I have a white all-around light on the hardtop. Rule 23 says that's only allowed for boats with an LOA shorter than 12 meters. My 2007 370 is 40 feet (12.2 meters) long. So I am required to have a 225-degree masthead light mounted forward, and a 135-degree sternlight. The all-around light is not legal.
The other problem is that the original lights aren't bright enough to be legal. A couple years ago, I upgraded my nav lights to the brighter 3-mile and 2-mile lights. I did it to improve safety. Well, now I realize that Rule 22 actually requires those lights for a 12-meter boat.
This picture shows two green sidelights shining on a wall: a new 2-mile light and the original light. Can you guess which is the new 2-mile light?
The visibility requirement for a 12-meter boat is 3 miles for the white lights and 2 miles for the sidelights. The lights might have a visibility rating stamped on the case. My original "festoon bulb" lights were downright feeble compared to the ones I installed.
It's legal to use underwater lights or other lights when underway, but only if they can't be confused with the nav lights, and they don't impair the vision of the crew.
You can move the all-around to the front of the arch. You'd have to make sure it doesn't illuminate the foredeck (which would kill your night vision). Might have to add a light baffle under the light.
If you use a sternlight, it just has to be lower than the masthead light.
Something like this would work!
https://www.amazon.ca/Owfeel-Control-Compatible-Application-Program/dp/B07SG48KSW
https://www.amazon.ca/dp/B098TGGPH5/
https://new.attwoodmarine.com/powerbase/
Raises and lowers mast light at the touch of a button
The nav light fixture is USCG approved as a whole based on using a specific bulb. To keep the USCG rating the bulb must be replaced with the exact type and rating of bulb, not an equivalent. So if it originally came with incandescent, it's supposed to be replaced with an incandescent (even though the LED may be superior).
https://www.hellamarine.com/en/blog/news/retrofitting-incandescent-nav-lamps.html
The article is 10 years old so not sure if regulations have changed, but here's the text from the link:
Retrofitting Incandescent Navigation Lamps with LED bulbs is unsafe and illegal.
With all the power-saving and longevity benefits of LED lights, it's easy to see why boat owners replace traditional light bulbs with LEDs. But doing so with navigation lights can violate the fixture's certifications. This has serious consequences, as US Inland Navigation Rules and International Navigation Rules carry the force of federal law.
