Project List for 2022 - 360EC
pcmpete
Member Posts: 110 ✭✭
Decided to document this year’s project list for my 2010 360EC.
Current Setup:
Twin 377s with Bravo IIIs
Axius with Skyhook
Project List:
1.
Change all four batteries to AGM group 31, currently Group 27 Flooded Lead Acid.
I am getting random errors on my vesselview and have read that it is recommended AGMs for the DTS/Axius system.
2.
Change out the O.E.M. Battery isolator.
I am thinking of TWO Victron isolators with very little voltage drop. I know people on this forum use the ProMariner and some have had issues.
3.
Add a NMEA2000 wiring system.
Include a Vesselview link.
Connect up to existing Fusion Radio (with NMEA2000)
4.
Upgrade my Lowrance HDS 8 Gen 2 to Simrad GO12
5.
Replace my Vesselview 1.5 with 1 or 2 Simrad GO9s
6.
Replace ALL cockpit lights with tri-color leds
7.
Upgrade to Hill Marine 4 x 4 props.
I currently have 4 x 3 21pitch
8.
Replace the Lenco Trim Switch
with either the newer all-in-one switch or the Bennett Autotab Pro
Hopefully by documenting my projects I will get help and feedback from this forum along the way.
I plan of updating and adding items as I go.
First I will split the projects in to Must DO and Want to do.
Current Setup:
Axius with Skyhook
Project List:
1.
2.
3.
4.
5.
6.
7.
8.
Post edited by pcmpete on
No issues with my ProMariner stuff.
What batteries did you use?
I miss those Lenco Trim Tab indicators & auto retract on our Rinker 276. They worked very well.
Our current boat has Bennet tabs - which work fine....but no indicator & no retract.
Be nice to refit.
