Charger issue
 JakesRinker300
                    Member Posts: 91 ✭✭
JakesRinker300
                    Member Posts: 91 ✭✭
            Hello all. Experienced a charging issue on our new to us 95 300. Shore power was charging batteries and then one day discovered dead batteries. Checked main panel and it was on. Checked charger and the reset button was popped out. When I push it in the charger hums for a few seconds and then the reset button pops out. Is this for sure the charger or could it be something else?
Jake
Jake
My charger wasn't wired into the isolator iirc, only the alternator. Been 2 years or so now.
I always cross-shop Amazon against Marine Outfitters or The Chandlery. Also, in years past The Chandlery has always had a boat show sale with 20-30% off.
Same with the output wires ... butt connectors for all. I'm not sure why your old charger had two green wires. It's normally one ground and three 12+ outputs.
