Engine smoke
Has anyone experienced very light white smoke t high revs/28knots. No issues with performance or temperature but not seen it before. Water temp is 9deg and ain’t temp is 6deg so was thinking possible condensation?
If gas check your pcv grommet seating.
If diesel check your ccv... theyre the same thing just called different names.
With the big delta of temps from internal to external on that engine, it's a recipe for escaping blow by.
