Stainless Waste Tank?
Hey folks, not sure if I was dreaming or if I actually read this someplace but is having a stainless steel holding tank a bad thing? I can see it eliminating the "suction/caving in" thing that plastic might have but are there other reasons as well? We still have quite an odor coming from inside the cabin someplace and I've read several fixes that people have tried to eliminate it but could a lot of that be caused by the stainless- waste mix? I plan to change out the hose from the head to the tank for next year, replace the joker valve again, clean the area around the A/C (which seems to be where a different kinda smell than the cabin funk is generating from. Almost like an old uncleaned truckstop urinal). Anyhow, should I change the stainless to plastic??
BTW one benefit of a plastic tank is that when your tank sensor stops working, you can see the level through the side of the tank.
