Kohler 5EKD generator fuel pump module leaking
oscar1oscar1 Member Posts: 773 ✭✭✭
I have to replace the fuel pump module($647.59) in my 5EKD because the gasket has small fuel leak, but the module still in great condition, so I wonder what material should be the best to use to make a new gasket to the repair of the fuel pump to keep it as spare part for the future. The original gasket is 1/16" thickness, so should i use the same thickness or go higher to 1/8" for the new gasket. I called Kholer, but they don't t sale any repair part for the pump. Any ideas will be appreciated. Thx.
  • Aqua_AuraAqua_Aura Member Posts: 2,678 ✭✭✭✭✭
    Take that gasket to a good auto parts store or shop and get the material matches or equivalent and then trace and cut. In my area I would use NAPA but not sure what you have locally.
    There is liquid gasket in a tube that might work. Hard to say without feeling the material.
    Worth a shot at spending maybe $10 and some time before you drop $600
    The base gasket material is not the concern. The silicone or viton seal portion is (the trace lines you see). Those are what do the sealing when compressed.
  • aero3113aero3113 Member Posts: 9,419 ✭✭✭✭✭
    I agree, maybe find a sheet of fuel safe silicone or rubber material. Or use a thicker gasket material with a good fuel safe sealant.
  • oscar1oscar1 Member Posts: 773 ✭✭✭
    Can the silicone or viton seal portion add to the gasket during installation?
    @oscar1: short answer: no.
