Believe 2003 should be smart craft so you could go with vessel view blue tooth and install a touch screen device and go digital. That’s what I would do in this case…… assuming your 03 is smartcraft
Thanks all I sent a picture to Faira and they said they were probably teleflex. Greatlakes skipper had some similar but not a match. I will try reaching out to teleflex next. How can I tell if they are smart craft compatible. The gauges are just foggy but still functional. 2 tachs and speedo.
I doubt they are Smart craft compatible. If you have Volvo engines ,they are not. If you have Merc it is doubtful for 2003 but research your engine serial #.
My 2003 310 is. The air intake cover decal if original will have the SC in a diamond but Merc can also confirm via serial number. As the 312 was the updated 310 I would say it is.
I have the exact same issue...2003 342, with mercs...they have to be Teleflex, isn't that their logo in center, the throttle that looks like a "T?" Does anyone know if you can just transfer the wires to a different vendor's gauge? Like these Farias?
https://www.wmjmarine.com/tel63474p.html
2019 MTX20 Extreme
