Anchor Locker leaking water
Serenity
Member Posts: 162 ✭✭✭
I have a question and would like some opinions.
I own a 2005 320 and I noticed the line and chain in the anchor locker under the windlass was wet. I first thought the drain from the windlass area was leaking. Upon further inspection-the drain was fine but the bolts holding the windlass and wires from the windlass were wet and are the reason for the wet anchor line. Do I need to take my windlass out and re-seal the bolts and wires. We did not have heavy rain--I only washed the boat today with no direct water in the windlass area. The water does drain overboard since there are drains in the bottom of the anchor locker. It is just that I am sure mold and mildew will grow like a weed with water and darkness all the time. The perfect environment.
