Rinker 280 EC Battery Switch Panel Removal
2006 Rinker 280 EC, hoping to modify the wiring a bit so my house battery doesn't go dead every week on the trailer. Part of that includes wiring an MPPT controller inline on a few circuits that will be always on, and removing a few circuits that don't need to run on the trailer (MerCathode, for example). The MPPT controller will shut off the load when the battery gets critical.
Here's my panel: anyone ever pull this one off? Is it a nightmare, or can I remove just the 2 dozen-something outer screws? Any gotchas (like the backside of the bracket will fall down into the bowels of the boat where it can't be reached)?
Thanks in advance!
Thanks in advance!
Yes, many Rinkers were wired so that you have to turn on the key to play the stereo. That's normal.
If your batteries are dying, there are lots of things to consider. I don't know your boating experience, so I'll keep it generic:
How old are the batteries, and what kind? If lead acid, have you topped up the water in the battery cells?
Have you replaced the battery charger? From that we've seen, they tend to last 10-15 years. I've replaced both of mine in my '07 370.
