Looking for tips on maintenance.
Over the winter, we bought a 2002 FV 310. We have been having a great time so far. This is our first boat, so I am looking for some advice on small maintenance things I should/could be doing throughout the summer. Any advice would be welcomed!
I've found that my engine hours and my maintenance are strangely related in terms of hours.. and that is with a tiny 212+ trailer... I can't imagine caring for a boat the size of yours..
I'd start with repairs, then move ultimately to preventive maintenance such as waxing, pulling electrical plugs and greasing to catch and prevent corrosion, move from stem to stern with your notepad and write it all down, with three columns of priority as you go.. it will be depressing around the end of the first hour, but know this: your boat will never let you down if you don't let it go.. there are dang few things that fly apart without some sort of warning. When you're down to charting and forecasting maintenance on a schedule, you're ahead of 90% of us.. and when that list includes rope inspection/maintenance, and you're doing so whilst sipping an adult drink on the dock- you've won.. :-)
Welcome to the site! I had a '02 310 for about 7 years. Fantastic boat and very easy to access what you need to for maintenance (except the impeller on the generator is a bit tough).
as mentioned, fluids is a good start. Impellers every other year is another good one (if you don't know the condition, change them now). Outdrive service is a good start to so you know where you are at with them. when you start doing these things, you'll notice other items while you are in there you should do as well. Greasing the coupler joints twice a year is good. changing gear lube and engine oil each fall. Keeping your strainers clean and check every other week or so is good. Just dig in and start looking is the best thing you could do. Under your mid-cabin cushions, you'll see a couple seacocks and the shower box. the shower box needs cleaned out every so often.
Air conditioner air filters every so often need rinsed...I think that is a good start. Enjoy the boat as it is a fantastic one!!
