Upgrade smartcraft gauges to Vesselview
jmoen438
Member Posts: 98 ✭✭✭
2005 342 FV
I believe I have smartcraft gauges as they have the engine hours in the tachometers. How do I go about upgrading them to vesselview on an in dash monitor?
2005 Merc engines will be SmartCraft ready. You need the cables from the engines, each go to a separate J box, then the cable that connects both J boxes to one output. For the VV-903 you need the NEMA-2000 backbone too. Pretty much plug and play. There is set up on the VV itself. I added in A/D converters to have the fuel tank sending units feed into the VV too. It is a sweet set up.
