Bravo 3 trim ram anode screw stripped
As the title says.  Last season I lost one of my ram anode.  The threads are stripped out trying to replace.  Anybody have this issue?  There is very little room to try and tap the holes to a bigger size.
  • LaReaLaRea Member, Moderator Posts: 8,066 mod
    One screw is good and one stripped?  I'd put it on with one screw.  Or maybe get a bigger screw and try to self-tap.  Worth a try ... a new ram is $160, as I'm sure you know.
    Yep both are stripped.  I'm not buying a new ram just because of the anode.  I'll find a way...lol
  • YYZRCYYZRC Member Posts: 5,419 ✭✭✭✭✭
    Shocked at how (relatively) cheap a new ram is, given that it’s a Merc part.
  • raybo3raybo3 Administrator Posts: 5,614 admin
    How about using heli coil kit for the size of the hole. Amazoncom Helicoil 5521-6 38-16 Inch Coarse Thread Repair Kit   Automotive
    I thought about it...but there's just no room to run a tap straight in.  I'm going to try and run the next size up screw...which I think would be 12-24 and see if that holds.  If not probably go anode less on that ram.
  • J3ffJ3ff Member Posts: 4,224 ✭✭✭✭✭
    Could you drill the hole 1/4" deeper, tap it, and go with a longer bolt?
    @YYZRC - No room to get a tap straight in.
  • Pat310Pat310 Member Posts: 604 ✭✭✭
    Same problem this spring. Was told by tech they just put 3/4” shaft anode on like @J3ff suggested
    You could always pull the ram off the drive and disassemble it. The end cap should come off and you could put it on a bench and drill & Tap as needed.
    Probably need to reseal it with new O rings.
    @J3ff - Old thread but where did you put these clam shell anodes that still allows the ram to move?
    Should be lots of room on the shaft (3”+) as the rams don’t fully retract. Here’s a pic with rams retracted and no anodes.
    edited April 2023
    Just make sure to remove the paint under the anode. 3/4” anode
    Post edited by Pat310 on
    Okay so anywhere on the ram shaft is okay.  I was thinking it had to be close to the ram body.
  • WillhoundWillhound Member Posts: 4,241 ✭✭✭✭✭
    Yep. In fact, they won't even fit on the body. And if they did then you have all those seals and oil and whatnot negating the effect.
    edited April 2023
    Anyone have a link to a 3/4" magnesium collar/shaft anode? Boatzincs.com and Amazon (Martyr brand) show 1" minimum I.D. size for magnesium.
    EDIT: Found some on various sites. It's Martyr CMX-1 (3/4"). Item #CMX01M. They go for about $20/each.
    edited April 2023
    https://www.westmarine.com/martyr-streamlined-collar-zinc-anodes-with-hex-head-screws-P011046547.html
    They might be available in stock if you’re in a hurry. 3/4 x 2 1/2” long are what I used
