hello, Mr. High Five...
 212rowboat
                    Member Posts: 2,593 ✭✭✭✭✭
212rowboat
                    Here we go again... grrrrr....
I've got a lock on a NiB high five.. it is a 20p, which tells me it is a quicksilver and not a merc, but it is hubbed right and brand spanking new for a ridiculous price I doubt I can pass on, unless....
I'm happy with my s/s 22p 14.25" turbo by precision, but I've noticed the water boils off it while dropping speed and then popping it after intersecting wakes.. cavitation, if you would.. this was apparent after losing the hydro-foil 'whale tail' off the drive.. even said, the 22p isn't exactly right, and I was waiting for a 21p of similar or duplicate geometry to present itself before seeking it, if you know what I mean.. I like deals, in other words..
anyway, this five blade 13.75" 20p s/s has presented itself.. from what I've read, the high five plays by it's own rules and doesn't adhere to classic theory of function whereas once you've nailed a geometry with another prop (a turbo, a mirage, a laser, ect) you can dang near mathematically dial it up and in so long as you stick with the specific geometry..
abrupt progressive pitch, for one.. sizable vents... both help hole shot, and both help top end- allowing you to run a slightly higher pitch than you can with others- but this is a five blade, and it bites differently, and 'sposedly it allows for a uniform 'across the face' pressure of each blade regardless of that blades position.. this allows ridiculous holding in rough seas, which is what I'm aiming for... I want the bite.. some say it increases top end, others say it hurts it.. I dunno.. I don't care.. I want hole shot and low planing w/ between 3 and 5* bowrise on plane, which equates to better fuel economy..
so... that was winded.. sorry.. question is for those w/ high five experience... what effect did pitch have when you swapped? is it true that the 5 is equiv to a 3blade of similar pitch? or.. would I want to drop or add pitch? Again, this one is 20p.. it's going to be hard to say no to..
Floater: I found this precision turbo on eBay last year.. ready for this? $40.. $12 shipping.. $52 invested in a stainless steel flawless prop.. you make more ponies than I do.. you may be interested in running it? Mebbe I could ship it to you if you pick the costs up, you run it, if you like it... Call it $50? :-) ... Of course, this is only if the h5 works out..
Dave
+1 on the squirrely handling at speed, mine would launch onto a plane in a heartbeat and hold
a plane way down low but too twitchy and would over rev on top end but mine is a 17p with a 5.0
on a 192 I ended up with a 4 blade 20p no name I picked up on craigslist with a 3 blade Rapture
21p for $50 (I'm cheap too!) Have not tried the Rapture yet but like the 4 blade.
There is confusion, contradiction, old theory of three and four blade props applied to this one, applications of boats/engines/weight/hull design.. man.. the only two things I've accomplished to find and serve as fact is that the 17p is a bad design and should be avoided.. the 19p is the holy grail for boarders, skiers, and deep water barefoot types, and the 26p is faster than logic dictates... Oh.. and reverse.. reverse bites a big one with these.. I've read of blowing out the prop out of the hole, in hard banks with a shallow draft, relearning the trim game, and not as much stern lift as you'd imagine.. then there is a huge contingent that won't let there's go under any circumstances...
I dunno what to believe..
I trust your experiences, MT, and won't take them lightly on my initial voyage.. I'll be aware of reverse and whip her about backwards in open water to get an idea.. and while alone I'll run through a sweet lil channel I know of to see how she bites at an ever increasing speed..
One thing all agree to, and what attracts me to the h5, is the same mechanism responsible for grip in rough seas also allows ultra low planing speeds..
When I run it, I'll report back in detail...
One more thing- the turbo I'm running now isn't the best in reverse either.. the vents that allow my decent hole shot now, in reverse, ventilate the prop and lessens bite.. for that reason, the h5 will be used at least initially with the vents plugged..
I've already checked out hill marine (thanks for the tip!), and will be ordering a 19p 14.25" five blade... I'm about 4200~4300rpm with the turbo I 22p 14.125".. I'm thinking dropping the 3" will kick me up 600rpm, and be reduced about <100rpm due to swinging a bigger blade... That should put me at the top of rpm range of 4800rpm... According to prop calculator that accounts for blades, weight, hull type, power, and gear box, I should be at or around 48mph top speed, which is more than fine.. I should hold plane at around 16mph, again good, and I should be out of the hole in less than three seconds at 85% throttle, 0-30 in four seconds at same throttle.. Plus, the hill prop shouldn't be as bad in reverse as the h5, because it's swinging those bigger blades..
I'm almost certain my gearing is 1.62:1, but it could possibly be 1.81:1, which tosses those above calculated stats...
Ordering it tomorrow... When the wife isn't around.. :-)
even with the Hill prop, I figure I can get most of what I've got into it out of it if it doesn't work.
well..........
this is the precision turbo1, 14.25x22p three blade, obviously...
side by side comparison...
Ron Hill 'Pleasure 5' 14 1/8" x 19p....
I have to wait until later (hopefully this eve) to get a ride report.... One thing I noticed, is there is hardly any comprehensive reports/reviews of this prop anywhere on the web.... I'm aiming to fix that. :-)
