Bildge pump locations on a 2003 342
Hello I was wondering in a 2003 342 if there is more than one bildge pump. I've noticed that the carpet by the stairs and under the aft cabin storage compartment is damp. Is there a forward bildge pump and if so the location of the pump would be great.
I bet the water is from the shower sump box. The float can go bad or the screen gets plugged from hair/shower scum. That sump is under the aft bunk too, port side. Also check the A/C and toilet valves/filters too for leaks. Also under the port bunk cushion.
Let us know what you find!
