Aft bilge question
my 270 fv has a funky smell coming from the aft bilge this year. I sucked out the water in order to get ready to replace my pump and float. I noticed it appears there is a connection leaking at this box which also appears to be a pump. There are multiple hoses coming off the box. Can anyone provide insight as to what the these
hoses are to. FYI We do not use the bathroom on our boat if that makes a difference. We are the second owners and are not sure what exactly was done by the previous owner and what was done by rinker.
You can buy the shower sump with the pump and it's not very expensive and given how gross it is I would just replace it and if the old pump works save it for spare. Or if you don't use the shower just remove the sump box clean everything and put it back in if it works.
Currently on sale
Attwood 4143-4 Shower Sump Pump System, 750 GPH Model, 12-Volt, 22-Inch Wire, Large Box, ¾-Inch Interior Diameter Outlet Hose https://www.amazon.com/dp/B001O0DECQ/ref=cm_sw_r_apan_i_P83MEX72N6YWCDVC4TEK
