Where is that water coming from
frenchship
Member Posts: 1,079 ✭✭✭
Hi,
Lately I noticed that I had more water in my bilge then before after some investigation I found that is was coming from the transom of the port motor just below the drive shaft it is a constant dribble but hard to evaluate the amount over time.( Bravo111)For now I do suspect the bellows shifter or drive shaft but only have about 200hrs on the engine. My main question is could it wait until the season is over or should I do it now. I have the mechanical knowledge and all the mercruiser shop manual to do it but need about 500$ U.S. of pecial tools to do a proper job, plus the price of the parts 400$ U.S. And while at it probably should do both stern drives. Or spend the money and bring to the dealer. Any Infos or ideas or how to trouble shoot exactly where the water is coming from would be appreciated.
Thanks Paul
On the picture the green square show the drive shaft and the red square where there is some water .
You are better to deal with this now for a few reasons:
1. it will only get worse. leaking bellows are in the top 3 reasons a boat sinks at slip
2. ujoints and the shaft will rust, possibly causing oil to leak..now you have a bigger job and more $$$
I'm pretty good mechanically, but for this I think I'd take it to a Merc service guy. I'm sure some others can chime in, but between buying the special tools and your (and a friends) time is it worth it to DIY?
x
x
x
