Galvanic Isolator and AC Grounds
YYZRC
Member Posts: 5,366 ✭✭✭✭✭
I am removing the starboard shore power inlets and replacing with an inverter circuit.
The galvanic isolator as originally installed is wired as follows:
BOAT GROUND
Starboard shore power inlet grounds (??)
Generator ground (ok)
Panel ground bus bar (ok)
SHORE POWER GROUND
Port shore power inlet grounds (ok)
I don’t understand why the starboard shore power grounds were wired into the boat side of the galvanic isolator.
BOAT GROUND
SHORE POWER GROUND
Post edited by YYZRC on
