Speedometer
clbkabclbkab Member Posts: 15 ✭✭
When I put my boat into the water last month the speedometer does not register.  Any suggestions on troubleshooting?
    Most speedometers work off water pressure, meaning there is a hole in the front of the outdrive, or a tube off the transom. the faster the boat goes, the more pressure there is. Usually the hole gets plugged and it stops working. Once you find the hole, try cleaning it out with a piece of wire.
  • clbkabclbkab Member Posts: 15 ✭✭
    I'll check that out, I have a Bravo 3 out-drive which was winterized by my marina, perhaps they did something to it during the process.
    Either the hole is plugged, or the tube connector was not put bak on right (it has to be undone to remove the drive).  Either is an easy fix if you are out of the water.
    I will be pulling the boat for cleaning and maintenance next weekend and will check it out.  Any illustrations as to what I am looking for on the Bravo 3?
    The inlet hole is on the leading edge of the lower unit, about mid-way up from the props.  A small pick will open it up if plugged.
    The hose attachment is on the upper drive portion leading into the transom.  Hard to explain.  See this link, page 88
    edited June 2014
    If all of the good advice above fails - try removing (carefully) the rubber/plastic tube on the back of your speedometer inlet (barb) that runs from the pitot tube. Use a SMALL household air compressor to GENTLY blow air back through the tube. That clears 99% of blockages. It will blow them right back through the line and out the pitot tube. Son #1 doubted me one time and was looking at the pitot tube hole in disbelief that my plan would work - only to get a face full of water and seaweed bits LOL - who said parenting wasn't fun :-)  Make sure you zip tie the tube securely back onto the speedometer barb ( i now use two zip ties) or you will have water dripping onto your feet - ask me how I know that :-)  MT
    finally was able to pull the boat and it turns out when I had the boat serviced the speedometer inlet tube was left disconnected!
    If only all boat issues were so easy to fix :D
    Congrats. Mike
  • MarkBMarkB Member Posts: 3,996 ✭✭✭✭✭
    Haha, yeah, that's a quick and easy fix.
    Get a long 1./8" drill bit JB Weld a large wire nut on the end put it in a zip lock bag with a little oil to prevent rust and keep on board it will always come in handy
