Volvo Beeping
mvn
Member, Moderator Posts: 763 mod
2019 Volvo V6-280 with SX drive. About 11 hours total on it now (sat in storage for a number of years. Has been running ok when I got it the other week. This weekend it started to beep once every minute and limits engine speed to 4200 rpm. Manual says engine protection mode is activated. If I come back the next morning, all good for a while but after running, it starts the beep code again.
Any ideas?
Mark
Any ideas?
Mark
Good, fast, cheap.... pick two.
2019 MTX20 Extreme
2019 MTX20 Extreme
2019 MTX20 Extreme
First thing I did was run over to the local Volvo dealer {5 minutes away) and grabbed a new fuel filter. I also put a can of Sea Foam in the tank. This boat has been in storage for over 3 years with a 1/2 tank of gas so who knows what is lurking in the filter. I crawled down into the engine bay and I just started to slip the filter wrench over the filter when I saw that it was barely screwed on! I replaced it with the new one and properly installed it. After purging the air out, I made several runs on the lake to try and reproduce the fault but no go..... No faults!
So much for the dealer checking everything over during prr-delivery inspection. I'm thinking the filter was sucking air since I now realize the low pressure pump was gurgling every time I keyed up.
Couldn't have done anything without the scan tool.
Mark
2019 MTX20 Extreme
