Filter for waste tank vent on 342
I’m helping my friend with his 2005 342,
getting a stank odor when flushing the head. I have a 320 and replaced the Big Orange soon after I bought it.
What filter is OEM on the 342?
If there is none, where can we put one or a different waste vent filter?
My OEM filter on the 06 342 was way up above the generator fuel shut off valve. Get in there and look up and you can see the hose (and hopefully the old filter) going up and out the vent hole to outside
Pretty sure the 342 would have come with a SaniGuard 310002 when built. That filter was very common OEM back then.
It has a standard 5/8” inlet/outlet. Model discontinued but as Liberty said - any filter will work with 5/8” hook ups.
Waste vent filter is pretty mechanical. If you've replaced media & vent lines aren't plugged....I'd bet it's the sanitary hoses.
Thanks. When I pulled it out of the old boat to put it in the new one I had to replace all the adjoining hoses. If you put your sniffer around the filter itself then you can smell the odour . I just think that maybe over time the plastic leaks the goods
Although, if the big 1.5" sanitary hoses are 10+ years old. They should be on your to do list to replace. That's about their lifespan.
