Rinker 310 EC Swim Light switch?
oscar1
Member Posts: 803 ✭✭✭
I have a switch with a label "swing light" in my console panel which I cannot find what its is turning on or off. I will appreciate If anyone have any idea where these wire go to. Thx
https://rinkerboats.vanillacommunities.com/discussion/comment/129747#Comment_129747
I am pretty sure Rinker used the same wiring harness in all their express cruisers.
This was my original panel marked "Swim Light" (bottom row, 4th from right). Should be same as yours since we have same model 310 EC...
When I upgraded my switches I changed the name to "Underwater Lights"...
If you don't have lights installed, then the wiring is as @YYZRC says so you can install some.
I added a switch so that they are not always on with the cockpit lights.
