Changing thru hulls on 270fv, toilet and AC?
J3ffJ3ff Member Posts: 4,162 ✭✭✭✭✭
How complicated is this job as far as you guys know? I found something on the toilet inlet that I'm not so sure that I like. It was a little bit of what looked like a gasket hanging out from behind the metal on the bottom of the boat. The AC side has a valve that even when closed drips water, just a drop, every 15 seconds. I solved that problem by putting another valve on the other side of that but if I'm going to do the toilet inlet then maybe it would be worth it to do both. Let me know what you think as far as how complicated the job is.  At this point I think it is probably fine and they both have been water tight since 2004, just didn't like what I saw yesterday on the toilet inlet.
Post edited by J3ff on
