Drive trim DOWN doesnt work in N, but does work in FWD or RV
Onward we go with repairs...
Anyone had this happen to them?
For a long time now the only way to get the drive up has been to hit the trailer mode button (the second click on the trim up button).. now it simply doesnt work going down at all, unless you move it into FWD or Reverse..
Going to wait till I get it out of the boat yard to fix it as I'm already over by a week.. just wondering if it's a simple connection problem, or a much bigger issue.
Here is the pump and two trim relays... check the connections and in particular the ground wire(s) on the frame. on the picture below the grounds are all attached at the top with the three black wires.
If it is corroded or dirty at all then clean that up.
The two relays are also susceptible to failure. They are the same relay as the motor starter solenoid, so worth having one as a spare.
Hope that helps.
