windless on my 05 320 FV doesnt go up with
my windless when we try to raise it up, it seems to skip and drops back and goes back up , but struggles . After a few trips of the breaker and reset and then finally raising it out of the water. Can it be the clutch needs to be tight or is the control arm needs to be replaced? There is no tension on the control arm.
@Spyderweb as per above.
Sounds like first thing - is to tighten clutch to get more grip on the anchor rode/line.
Go from there.
https://www.p2marine.com/simpson-lawrence-control-arm-kit-for-horizon-600-900
If you look up the manual for your model of windlass, it will specify the chain sizes that will work. Then look at the chain for stamped markings.
