It's the summer of Fixes over here.. "fixed" the trim down problem... now the boat wont start/run!
Had a wire cut in the throttle lever up front, drive wouldn't go down. Fixed the wire. Now the boat wont start... something must have broken inside the shift control box..
Can't find the exact same one... does anyone know if this will work on a 2004 single engine FV 270?
https://www.amazon.com/Mercury-Quicksilver-Parts-8M0011213-CONTROL/dp/B00475GFM6
The only difference I can see is that the part that allows you to engage forward in reverse is on the front of this one, vs on the side of mine... (which, I found the part that is supposed to lock out forward and backward was broken too!)
Here's mine..
Here's mine..
It ended up that while messing around w/ the controls I knocked it into reverse without the engine on... and with the handle off lost track of where "N" was.. so in order not to break anything, I bypassed the N cut off switch, cranked the engine and lightly pulled on the shift cable to get it back to N. A few seconds later all was good again. Greased everything I could inside the shift control box, put it all together and off we go. Seems to be good again.
Okay, what's next??
