Kohler Gen
2006 Rinker 270
Tried searching and didn't find anything that was helpful.
Ok, So yesterday while we were getting ready to leave the cove we were anchored in the boat wouldn't start because battery1 had run down. So I went down to the control Panel, and started the gen(I think). After it was running for a brief second I noticed that I had started it with the gen switch in the on position. So I turned it off and back on, and turned on the battery charger. When to start the boat, nothing. So I turned the battery switch to 2, and the boat started right up. Got the anchors in and started to make the way back to the docks. I kept looking over my right shoulder for the water out of the hull for the gen exhaust, but I didn't see anything.
Made it back to dock without a problem, and never saw any water out of the hull(exhaust port). Pulled into the slip, tied up, and turned off the engine.(looking back I am 95% certain the gen wasn't running at this point). Waited for a buddy to back the trailer down the ramp, started up just fine, trailered it just fine. Shut engines off, and got up the ramp. Then I started my walk through and found that the gen was still in the on position. So I flipped the switch, but at this point it was 100% off before I flipped the switch out of the water and up the ramp.
Today I took the boat out just to see if the gen would start and maybe check into a thing or 2. Back the boat down the ramp, went in a bit further than I have normally to get the boat out into water. Engine started and ran just like normal on battery1, but when I tried to start the gen nothing. So I opened the engine hatch looked at the panel and tried to start from the gen itself. There was 3 clicks and nothing. So I went down to the control panel and flipped on the blower motor for the gen(previously even yesterday I had only been using the blower at the helm). The blower motor turned on, press the button 3 clicks. So I gave up and pulled the boat.
Ideas, Thoughts, Suggestions.
Thanks Brian
I work at a car dealership so I was going to pull the batteries, and have them tested tomorrow just in case as another thread on here talked about week batteries. Also Was going to replace the impeller as I watched a video earlier on how to do it for the Volvo motor. Seems straight forward enough. On the bottom front of the engine. Also I don't know when the last time it was changed as I just got the boat in April. So better to be safe as everyone says replace the impeller all the time basically.
Is there any type of prep or bleeding of the system for the impeller replacement, or simply unscrew cover remove and replace?
you can simply remove & reinstall impeller, then start (of course with boat in water). Some people may say lubricate with Vaseline a little, but I never have with no issues.
I've got the same kit craig mentioned & keep most of my spare parts in it for everything.
So after having the boat plugged in Friday night and all Saturday the Gen started right up on Sunday. However there was no water coming out of the exhaust. So I shut it off after about 15seconds of running. Went out to the cove we hang out in, and started right up again. Again there was no water coming out, so I shut it off after about 20seconds.
So good news gen runs, bad news no cooling?
Exhaust gas does come out through the hull, and the flappy cover.
After that, I am at a loss. Sorry. I can tell you the last time that it worked it ran without water for a very brief time then water would come out. That I am guessing is the priming that you are talking about. Is the strainer on the bottom of the boat?
Im sure these are stupid questions.
