Aft Bilge pump wiring 2005 320 FV
I went to the aft bilge under the seat cushions to clean/replace the AC seawater filter basket and discovered about 2 inches of nasty standing water. Probably been there for a while and causing the slight musty odor in the cabin.
Does the helm bilge pump switch control both this pump and the one in the engine compartment?
Is there a breaker I should be looking at?
Is there a separate float switch or is this an all in one automatic pump?
If it has a separate float switch, how do I wire an all in one? (having one delivered today)
What else should I know about the bilge and how should I clean up that area?
Replaced the sump pump yesterday and the bilge pump today.
