Windlass
jaubry
Member Posts: 125 ✭✭
Question,
My windlass has power to the unit. The batteries are fully charged. When I depress the up or down button on only get a click. The power draw is not great and doesn't drain the battery.
Is there is relay or solenoid? Seems the power isn't getting getting to to the motor.
Once you determine if it's the windlass or the switch, you can than decide to upgrade to a switch and relay setup. This prevents the amps of the windlass going through the switch, and only the relay.
It's easy to pull the switch and see how the voltage gets switched around depending on direction. Use a meter and it will tell you if the switch us doing it's job or not. I think I had to cut my wires at the windlass to check for power there, and reaching in the access can be a pain but not to big if a deal.
Speaking of windlasses, we anchored our 360 for the first time this weekend at a popular spot. We couldn't believe how many "captains" used their windlasses to pull the boat towards their anchors (even against a decent headwind) when leaving AND how many "captains" tried to break their anchors free while the rode/chain was at a significant slope. How do you say let's burn-up our windlass? As I am sure all of you do, we motor slowly towards the anchor to take the load off the rode (hey, that rhymed!) but not so much as to create excessive slack and then position the anchor roller slightly ahead of the anchor to break it free. BTW I read on this GREAT forum how to make a Prussik Knot which we have practised making and will use on windy days! MT
and a Prussik Knot is what?
Hey Ras, there is a thread on the forum about this but you can "google" it and there are videos. Essentially you make a bridle attached to your anchor line with both ends of the bridle attached to your forward cleats. Then you take the load off the main anchor line thereby transferring it to the two cleats. This saves you from the potential of a bent bow pulpit/roller assembly. The Prusik Knot is a slip knot that was developed by mountain climbers and is very easy to make. "Google" it for a great video(s). MT
A much better idea RY. Obviously, it fit in the Rinker oem locker. What length and type (G4?) of chain did you use? MT.....of course the use of chain does not obviate the need for a prussik knot as the knot is meant to save your pulpit/roller not the rode.
Yes. BTW...RY, what was the total length of chain you used - the oem from Rinker was 130' line + 30' chain. Did you use 160' of chain?
ah so much to learn....that's a lot of weight in the boat if you have 160' of chain! God forbid you have a windlass problem and have to pull that by hand...or, the strain it's putting on the windlass pulling up all that weight!
I will google that MT, but, if you tie the line off to a cleat, how would it bend the roller anyway???
Ras, you tie it off to TWO cleats, like a harness or bridle to spread the load. I have friends who tie their rode/chain to the cleat in their anchor locker but because it still goes over the bow roller/pulpit assembly it can bend it like a wet noodle in wavy conditions. The Prusik Knot takes all the strain off both the windlass AND the bow/pulpit roller assembly and spreads it between the two bow cleats.Tthe guys on this forum discussed the PKs many virtues last year and their advice was - as usual - golden. MT
wow Yan, I would have thought a LOT more than that.....MT- that makes better sense...keep in mind I just got mine working and the only time I used it was the street in front of my house! Made a heck of a clunk when it hit my trailer but what a sweet sound it was! I will check out the PK's, another advantage I would think is it would keep the boat straight to the wind/waves rather that tying off to the side where it would constantly fight the same.
100% Ras. MT
i appreciate any advice.
