Merc 350/377 Balance Point?
YYZRC
Member Posts: 5,367 ✭✭✭✭✭
I need to replace my steering pins once the season is over. My plan is to move the engines forward around 14" which should give me enough space to unbolt and remove the transom assemblies.
I intend to build an A frame on either side of the hull with a beam that spans the cockpit by which I will lift the engine. I'm planning to make a temporary mount for the engine to sit on once I move it forward. It looks to me like the mounts are near the mid-line of the engine; does anyone have a sense of what I can expect in terms of weight distribution? I need to jury-rig something to keep the engine from toppling when it is in the temporary forward position since the transom assembly won't be there to support the rear.
@Grahamu I know you had your engines out - thoughts?
Post edited by YYZRC on
Think of the time and money you'll spend to design and build an A-frame, rig the temporary foundations, and move the engines. A local crane service can probably remove and reinstall them for $400. Then the transom work will be so easy that you'll actually enjoy it.
Either way, hoisting the engines will be faster with a engine leveler like this:
https://www.amazon.com/Torin-Engine-Hoist-Crane-Accessory/dp/B004PX4YCI
I would have to pay the marina to pull the engines (cannot bring in an outside contractor) or I would have to move the boat off site for the winter (pain in the rear). Marina quoted 10 hours/engine for re-and-re, and I would have to do it all before shrink wrap.
I will order an outdrive jack like @aero3113 purchased so I can bring the drives and transom assemblies home for the winter.
To be honest, I'm looking forward to the challenge!
