Check Your Hot Water Heaters!
aero3113aero3113 Member Posts: 9,505 ✭✭✭✭✭
When I was changing the oil yesterday in the engines I noticed some salt around the hose end where the raw water goes into the hot water heater. I wiped the salt and all of a sudden I had a decent leak. I wiggled the hose and the barb and hose broke off! Luckily I found this now then it blowing off while underway. There was enough of the pipe left so I was able to just reattach the hose. I will need to cut and create a flair to hold the hose and clamp secure. I do carry a straight union to join the hoses together if the heater ever failed on me out on the water.
