Rinker 350 transom and bottom cracks / discoloring
Mylo
Member Posts: 44 ✭
I took some pictures of boat i am looking to buy, the bottom back by the transom has some cracks and discoloring and up on the stringers it looks like a crack in the fiberglass on both stringers, don't know if this is seroius or a cosmetic issue. Having survey done in a few days but would like to get feedback first, any comments would be appreciated
And obviously, there has been standing water in the bilge, so check for leaking transoms.
I had an 07 246 that had some cracking in the gelcoat on the inside of the transom, turned out to be just a **** application of the gelcoat. Let us know how they diagnose it.
https://rinkerboats.vanillacommunities.com/discussion/13165/2008-280ec-rotten-transom/p1
Most are not so severe and just cosmetic. Did you do the sea trail yet?
@Mylo
We had the skim coat of gelcoat crack up like that & shale off on both our 246 & 276.
Wasn't a problem.
That said Mylo - survey is the key. Don't sign any deals till completed.
https://www.jrmarine.com/instructions.htm
They rust due to age, my boat is low hours and fresh water and failed after 10 years or so.
2015 Scarab 165G
Laser Sailboat
2002 Seadoo Explorer
2023 Seadoo Spark Trixx x 2
If there's that much water coming in your screwed either way
The boat came to me with the extra batteries( which were all replaced in 2020 also) only problem does not help with lean to Port so I have made a rule all extra beer, pop, and water be stored under the couch in the cabin on the starboard side. I removed the board there for extra storage and the cool thing the bed still works with the storage under it.
2015 Scarab 165G
Laser Sailboat
2015 Scarab 165G
Laser Sailboat
