Leak Source - 2014 310 EC
Any suggestions on how to track down a potential leak from under the forward berth steps. As seen in the photos there was wet carpet and darkened flooring - which I noticed after we arrived at our boat yard for the end of season. Carpet was damp, not wet. There is no way to visualize under the steps without taking them apart. The berth wall is solid to the steps and nothing wet there. The sink wall is also solid to the steps, and no leaks there.
So anybody ever take these steps apart - and how did you do it? And - any potential areas I should look at that would make water end up in that area?
@oscar1 - That's what my friend suggested. Another possibility for me to look at. My wife did empty the freezer shortly before, so it could be as simple as ice cubes that melted.
I did have a project in mind that requires the modification of those steps, so I think I will start fishing around for those screws and try to take it apart gently.
The 4" stainless screws were a bear to get out. Best I can tell they carpeted each piece (wrapping it around the back) then put the two pieces together then dropped it in as a unit and then screwed it down.
Anyway, as you can see there was a lot of wetness and mold where the step meets the floor line and it seems to be under the flooring.
Thinking back, the galley sink was leaking earlier this year (from a broken drain) - and wondering if that water found it's way under the floor.
The only way to visualize under the sink area is to take out the fridge, which I plan to do next. Is it just a matter of removing the six (6) screws on the face frame and sliding it out - or do I need to watch for anything else?
I also have a plan up my sleeve to make some new storage in that area. So once I come up with a rendering I'll run it by the group to see what you all think.
