Underwater LED Lights
rinkedout
Member Posts: 5 ✭✭
Hello All,
I am new to this forum and recently purchased a 2013 290 EC. I am considering underwater LED lights on the transom. Anyone have any experience with this install. Will 2 high output LED's be enough or will I need 4?
Any guidance on long term stability of LED lights before drilling holes in the hull?
Thanks in advance,
RinkedOut
RinkedOut
I just installed 3 Lumitec Seablaze2 on my 08 EC330. These are great lights. ice solid housing. You only need to drill a 1/2" inch hole in to the transom. seal it with 5200 and you good to go.
I already had two on my 05 FV270 and had no issues with them.
Go to www.boatersland.com they have the best pricing
http://www.coastalnightlights.com/orders.html
I know the rage is all about LED lights, but I still prefer the Halogen 100 watt Perko lights. These lights will litteraly glow the water for 30+feet in a dual configuration. I have a single on our inboard and close to 20' behind a consistant light. Oh, and the "white" light is legal to have on while traveling. The "blue" LED is not. Be carefull while underway. Check it out
[URL=http://s957.photobucket.com/user/alswagg/media/underwater lights/Underwaterlighting011.jpg.html][IMG]http://i957.photobucket.com/albums/ae55/alswagg/underwater lights/Underwaterlighting011.jpg[/IMG][/URL]
[URL=http://s957.photobucket.com/user/alswagg/media/underwater lights/Underwaterlighting003.jpg.html][IMG]http://i957.photobucket.com/albums/ae55/alswagg/underwater lights/Underwaterlighting003.jpg[/IMG][/URL]
I will try to find it again, but it is common at least in our state of IN that only Red and Green on the bow and a White light on the stern, or midship. A blue light does not fall into these catagories. Another item which does not, is the dumb docking lights many are installing. If these are run while driving at night, a sure way to be stopped and inspected. Oncoming boaters can not tell which way you are manuvering.
I have even heard for a fact, the blue and green lighting for fishing have been stopped and inspected. This was not only from the sheriff but also from the DNR. As for power consumption, yes the Halogen does use more alot more. But, even in our own boat, we have never had a problem leaving on while at dinner or so. Good luck Al
I recently installed a drain plug LED light. Simple installation. I have a single drive. Here is a picture:
Mark
I have driven with my blue LED's on, but I try not to. When there is a large crowd on the rivers, like after fireworks, I only use them while rafted off and not while underway. You are correct Al, that is a quick way to get pulled over and have an inspection done. No need for that!
I got mine at the boat show. Here is the vendor link:
http://www.theliquidlite.com/
Did the girl in the video on the vendors website close the deal for you? LOL!
On a serious note, take note of a few things:
- the light base is stainless steel. Your plug hoder is brass. Wrap the stainless steel male end with teflon plumbing tape to minimize risk of galvanic corrosion.
- keep your old brass drain plug just in case.
https://www.imarineled.com/
