Deadrise Angle for new transducer
GlennyGlenny Member Posts: 28 ✭✭
Can anyone tell me the deadrise angle for a 2005 Rinker 320 Fiesta Vee. I am changing the transducer and need that measurement for the new one as there are three options available depending on angles. If not I will measure when I make it up to the boat and post for everyone here. (depending on location of transducer I guess it could be different....)
Thanks
    edited February 2023
    [Edit: never mind, better answers below.]
  • YYZRCYYZRC Member Posts: 5,478 ✭✭✭✭✭
    Should be 18 degrees.
  • IanIan Member Posts: 3,064 ✭✭✭✭✭
    Spec sheet for my 2003 310 says 18 degrees.
    2003 342 is 18 degrees as well. Seems to be a popular design.
  • GlennyGlenny Member Posts: 28 ✭✭
    Thanks everyone, it is 18 degrees I went and measured it on Friday. Ordered my transducer and will start the new project. Will post when its in progress.
  • rasburyrasbury Member Posts: 8,972 ✭✭✭✭✭
    Isn't it right at the transom? Do you have to adjust how it sits? Sorry for the stupid question...just my lack of knowledge..
    @rasbury the hole for the transducer sits right by the front of the engine.  There isn't any adjustment.  Just that there is an arrow on the transducer that you have to make sure is pointed to center of the boat.
    Well, I guess thats what I mean....so is it a setting? I'm wondering if your installing against the floor at an 18 degree angle...and a couple of inches in diameter angled at 18 degrees would be insignificant? I'm sure I'll have to deal with mine at some point...
    @rasbury.  No setting.  It is drilled perpendicular to the hull.  The 18 degrees is manufactured into the transducer.  So you have to be sure to purchase the right one.
    Ah....got it thanks...and I'm sure this info will lead to my next repair!
    Great conversation, all the questions I would of asked last year. Great site.
