Toilet and AC seacocks
TickledPink
                    Member Posts: 103 ✭✭
                    My first week of owning a FV 250 has been trying to say the least.
My latest issue is that the carpet in the cabin outside the toilet has become soaking wet. I checked the little compartment under the stairs and it's bone dry in there.
It's been suggested that the toilet and AC seacocks are always closed except when actually using the toilet and AC. Firstly, can anyone tell me where they are? Secondly, isn't it a bit of a pain to keep opening the toilet seacocks every time you need a pee?
Another suggestion was to check that the anchor compartment isn't full of water. Can anyone tell me how to access/check this please?
One thing is that I'm learning a lot and hopefully by the summer I'll be much less stressed.
Have you used the shower? Often the shower sump will fail and overflow.
Access to the anchor locker is usually found behind the mirror/panel in the vee berth.
I have had our boat for like 8 years now and just recently found the culprit. I would occasionally have a leak dripping through the ceiling panel of the midship berth. It would not leak with the mooring cover or camper pck up. I would put baby powder around suspect areas and hit with s hose and hit certain areas...got up under the captains chair and under the sink behind it with flex glue sealing everything I could...still leaked. Then, recently was washing the boat and I had all the seats pulled. Next to my helm there is a bench seat and then it curves. The seat base at that curve is a dry storage- I noticed after it got a lot of water in it and I was cleaning it out- I was going to grab the wet vacuum to suck it out- but the water was gone!. I cleaned s little better and discovered the previous owner had drilled holes in each corner- only problem there was no where for the water to go. It ruined the wood in that ceiling panel and it also ran into the bilge over top of the generator so now the cover and control box are all rusting out. Look for signs if damage and follow the trail. If you find a suspect area if you can put water in a bucket with food coloring to confirm....good luck and keep at it!
I've only had the boat for just over a week and as yet have not used the kitchenette sink or the shower. I' have used the toilet and bathroom sink.
I wasn't sure how to use the manual flush though. There's a left/right switch and an up/down handle (not used one before).
We've not had rain for a few weeks, it's been sunny but cold (I'm on the Isle of Wight) so no water has come in via the windscreen.
When I picked up the boat, it took 3.5 hours in choppy waters to get home. Could water have got in where the anchor is?
Ras makes a good point as well. Have you been using the freshwater tank and pump or did you connect a hose to your boat for freshwater? I always turn the freshwater pump off when underway just in case.
I haven't filled the water tank or pumped out yet. Literally all I've done is brought it from Weymouth to Cowes. I went back to the boat a week later and about an hour later noticed the wet floor.
The carpet dried out and it's stayed dry. There are no leaks from windows, ac, anchor compartment etc. so whilst I'm glad it's remained dry, it's a mystery how it became wet before.
I've filled the water tank and the loo has been used but I've not used the ac yet.
Thanks for all your help 🙂
