Looking for Idea on a 342
Ok all you 342 owners. Looking for an idea to replace the "glove box" on the back of the wrap around port side seat. The plastic on mine has really yellowed and looks horrible. I know this has been discussed before but I can't find it. Any help would be appreciated. TIA!
2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
Like @Dream_Inn said, I have nothing to lose, so I removed it today and applied the first coat of white spray paint. It bubbled a little, so I'll need to sand and recoat at least a couple more times.
I always hated that the shelf is too short for cans of spray sunblock unless you lay them sideways. So I made a couple cutouts in the top of the housing (won't be visible after installation). It also makes it easier to paint inside the shelf.
I like the cutout idea.
The cutouts in the top make it much more practical. If anybody else does that, be careful making the cutouts. Drill a 1/4" or 3/8" hole at each corner before cutting. If you cut it with sharp corners, it will be more prone to cracking over time.
Mark
2019 MTX20 Extreme
