Dometic 1065. Has power but doesn't turn on.
drbeep
Member Posts: 34 ✭
I have a Dometic 1065 in my 260 EC. It has power on 12v and/or shore. The light inside turns on when I open the door, but nothing else happens. I don't hear the compressor kick in or the fan spin. Nothing happens when I adjust the temperature knob.
I thought of replacing it, but it doesn't fit through the cabin entry without removing the sliding door which is an insane amount of work. Any idea what to check? TIA.
This might be helpful
https://www.combinoord.nl/files/service-instructie-cr-koelkasten.pdf
Thanks.
Where can I order a new assembly?
I only found sites outside the US.
https://www.everythingcaravans.com.au/products/pcb-internal-cr080-110#
https://www.everythingcaravans.com.au/collections/all?pf_pt_category=Upright+Compressor+Fridge+Parts&pf_v_brand=Dometic&pf_v_brand=Waeco
https://www.annapoliscruisair.com
But, I have an almost (was not working reliably on AC) completely operational fridge that I'm will to part out for forum members. I have this part in my old fridge that I can sell to you cheap.
PM me your address.
I just noticed the post. Yes, indeed.
Thank you for the offer.
