Vhf radio
 rasbury
                    Member Posts: 8,688 ✭✭✭✭✭
rasbury
                    I have such a limited boating area I never looked into connecting my 541 garmen plotter to the radio which has the distress button on it- what exactly does this do and how do I hook it up? I see my Garmin has extra ports...what is involved and will that give my location in an emergency?
From what I gather (and please correct me as I need advice too):
1- if you have a newer gps/chart plotter MFD like I do, RM axiom 12, you can connect an NMEA 0183 to a $150 standard horizon 1400 VHF or $170 Icom M330 VHF and get gps coordinates/MSSI on the low cost vhf and have all the same safety features of the built in gps vhf.
Open to comments on these two low cost VHF units.
2- connection is actually incredibly simple. There is a green, yellow, and maybe brown wire coming off of both devices that need connected by simple shrink/butt connectors. Depending on brands some wire colors may connect a little different but instruction is easily available.
3- if your older MFD does not have NMEA signal output then yea you need to buy the $300 or so built in gps VHF
im like you Ras where I really only use it 4-5 times a year to call in for a dock or call a friend when rafting up where there is no cell service but of course want to be fully up to speed for safety
did I miss anything?
Connect the 541 "in" to the VHF "out".
Connect the 541 "out" to the VHF "in".
On a Garmin 541, the colors are:
blue = 0183 out (transmit)
brown = 0183 in (receive)
Opinion: If your VHF isn't already connected to GPS, and you can't figure out how to connect it, install a new VHF. It's critical safety equipment.
https://www.navcen.uscg.gov/rescue-21-distress-system-coverage
Greenwich Bay, Rhode Island
@rasbury , you can send out a test to test the system.
Even with no GPS connected, you can still use the red distress button to send a DSC distress call. The call won't give your location, but it will continue transmitting until somebody acknowledges it. In an emergency, if you only have five seconds to spare, use it to press the distress button.
launched yesterday and was able to see that the gps coordinates and time come up nicely on the M330 screen from the chart plotter. For anyone reading this that has Raymarine you do need an nema wire from the hub which I already had and that tied in to the vhf nicely.
another project. Love Wago connectors!
