Water in gen oil learning experience
toolmaker312
Member Posts: 126 ✭✭
I used a bucket and hose to connect to kohler 5e to start out of water. I changed the oil and restarted. I left the bucket attached with water to start the next day for more maintenance. Luckily I pulled out the dip stick before restarting. It overflowed with tons of water. The next stroke of luck I decided to pull the plugs just in case of compressing water in the cylinder. Water shot out like a hose. I since reassembled and changed oil again, and is running fine. My guess is because the bucket was higher than the motor it entered the motor threw exhaust port. Should that have happened or am I missing some type of check valve?
