Bravo 3 drive install ?
Trying to reinstall bravo 3 Drive into transom. Alignment is good. I checked it with the bar. Something is holding it from going into the splines can get it into about half inche from studs rotate shaft but it won't engage and slide the rest of the way in. Going back in the morning taking a floor jack so I can fine tune the height. Have someone else helping me but looking for suggestions or hints from experienced people. Thanks for any help.
I put the drive in gear, make sure the shifter mechanism is open to receive the end of the cable.
I can't remember if it's froward or reverse. I gently apply pressure and spin until I feel it go in. Sometimes it takes some bouncing
R&R Bravo III Out Drive Part 2 - YouTube
As the drive seats into her final resting place the cable pushes it back into neutral. The cable pulls in for one direction and pushes out for the other. While I can't remember which gear I put the drive it in, it's the one where the drive side of the cable coupler is sitting proud of the drive mounting flange. Before I finish sliding the drive on I make sure the cable is seated properly while there's still a little air gap there. As you remove the bravo drive the cable coupler tries to pull the drive into gear. You'll want it to be in this position when reinstalling.
The final 3/4 inch or so I use a top and bottom but to gently pull the drive into final position with a 12 inch extension and a small 3/8 ratchet. It should gently slide in, no binding or hard cranking
I install mine while hanging from an engine hoist. Not difficult but as I'm only 170 lbs I know I'll need to eat my wheaties the morning of an install.
I will match prop speeds the engines will be off about 300rpm at cruise. Would even notice if I didn't upgrade to the nema data on chart plotter.
