I currently have a 4.3 Mercruiser with an aluminum 3 blade 14x21 and it will rev out to 5100 rpm !!! I am looking at a 4 blade SS Michigan 14x20. Would this prop give me a WOT rpm drop ?
I believe a stock prop was a 3 blade aluminum 19" pitch. I'd be surprized if it was over revving with a 21". Verify your engine speed with an accurate tach. The Faria tachs aren't very accurate.
When I had a 192, I believe I settled with a 4 blade stainless which had a 20" pitch.
Pretty sure factory WOT range for the 4.3 is 4400-4800 so if you like your engine do not run it that high. While adding another blade will probably drop your rpm down a bit, I doubt it would be enough to get in the range of a 300 rpm drop. Normally all things being equal, a change of one degree of pitch is about 200 rpm. First verify your rpm with a good tach and if accurate you probably need two degrees of pitch if same brand/style of prop or a degree and another blade. If buying this prop new, consider propgods.com for their advice and exchange program
Rinker sold but still have other boats Eastern LI, NY
Here's an example of the analysis I did a long time ago on the 192 I used to have. All of the engine details are listed. Note that the WOT range for that particular engine was 4200 to 4600. Yours may be different. I chose to prop at the high end of WOT due to my requirements.
Mark
2019 MTX20 Extreme
Mark
2019 MTX20 Extreme
2019 MTX20 Extreme
