loud airconditioner
have a 2003 342 fiesta vee, problem is the air conditioner is really loud when compressor kicks on and then stays loud whole time compressor is running. it almost sounds like it is pulsing, i checked voltage for surges but everything seems fine. unit was always loud even from new(it is original) but now you can even hear it outside the boat when your on the dock. thinking about trying dense carpet padding under unit, i think its vibrating through the hull. anyone else have any issue like this?
bmineo, I had the same problem on my last boat (310) that had a 12k unit. The rust started to cause the freon to leak. I went with a MarineAirrr unit. It was extremely quite and had a great fiberglass type drip pan (no rusting). I would highly recommend it. Here it is in a 16k unit (just an example, I don't know the seller). http://www.ebay.com/itm/205561700-Marine-Airrr-VTD16K-115v-16-000-BTU-Air-Conditioner-60-less-start-AMP-/230666408749?pt=Boat_Parts_Accessories_Gear&hash=item35b4ca132d&vxp=mtr#ht_6568wt_769
I may have to look into the foam thing for my aft unit. Thanks for the update!
