Question About Bravo 3 Impeller Kits
TonyG13TonyG13 Member Posts: 1,438 ✭✭✭✭
First time buying a replacement kit for our Mercruiser 350 Bravo 3 impeller. Used to have the yard do it, but now will attempt it myself to learn and save money.
Received the kit today (Sierra 18-3150) and looking at the housing where the impeller goes it is not a perfect circle. It is every so slightly oblong, measuring 2" X 2-1/4".
Is this normal and by design?
    Yes that is normal.
    Thank you!! Was freaky out for a moment thinking it was a machine molding error - but the plate holes lining up made me think it might not be.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,979 mod
    That abnormality is what allows the pump (impeller) to work correctly.  Where the vanes are compressed is where it pulls in the water.  A trick to getting the impeller installed is to use a good wire tie to pull the impeller vanes together to allow easier installation.
    Also use some dish soap along with the zip tie to get it installed.
    Tony- is it over heating or just maintenance? The flat surfaces will get groved as you may already know about- would hate to see you pulling it back off if so...
    @rasbury - Just buying for preventative maintenance and/or have it in case of emergency.
    Ah.....I unfortunately became an expert on my pump!
