342 blower issues
checkmate
                    Member Posts: 131 ✭✭✭
                    My blowers stop working on my 342.  I took both blowers out thinking they were bad and was going to buy new but I stopped myself.  I hooked them up direct to a battery and both of them ran.   Checked panel fuses they were good.  Pulled switch out to check it.  6 wire switch.......I'm lost now.  Don't know how to ohm check it.  Any advice????   Like to know for sure what the problem is b/4 I become a part put-on-er.  Light does cone on when I hit the switch.
There is a newer system out. Look at www.fireboy-xintex.com.
Hi.
Here is the answer I got from Randy Rinker in regards of the wiring of the fireboy. As you could read they did not get any complaints so it is being treated as an isolated case.
Paul,
We really did not get complaints about this, so these must be isolated cases. I have attached a wiring diagram for a 300. The Fireboy light gets its positive power from the ignition circuit purple wire. The ground is a black with yellow stripe. This goes back to the fireboy. The other black wire from the fireboy goes to the ground block in the engine room. If you disconnect both wires from the fireboy and the light still stays lit, then the black with yellow tracer is getting a ground somewhere else. It could possibly be mis-pinned at the dash connection with the wire coming from the fireboy light goint to a ground wire instead of the black with yellow tracer going back to the fireboy.
Randy Rinker
Warranty / Customer Service
-----Original Message-----
Sent: Wednesday, June 25, 2014 9:32 AM
To: Randy Rinker
Subject: Re: Wrong wiring on Xintex fireboy fire extinguisher
Hi,
Rinker 300 Express 2007 U.S. RNK88555K607. On the Rinker forum many with the 342 model have reported the same problem all factory installed .
Proud owner of a Rinker and thank you for your excellent service.
Paul
If Rinker boat owners don't check their fireboy and report the problem or correct it will stay that way and let's hope that it will never cause a major incident.
