This is going to be painful
davidbrooks
Member Posts: 1,430 ✭✭✭✭
I have been pretty preoccupied with all kinds of projects with a new to me house from last summer. I moved into a place on the water and the list of things i have done is pretty crazy. So the boat got neglected a bit. I maybe used 50 gallons of fuel last year. So, i get a break from home projects and go to do some maintenance on the boat. Had to replace a water pump and took it out for a test run. Couldn't get above 12 mph. Both engines started fine but i didn't have any more HP past half throttle. So started checking out the typical items. Checked wires, plugs, distributor and then climbed in the bay and scraped 2 months of barnacles off the bottom and prop. Took it out for another test run and when i went to start it my port engine wouldn't turn over very easy. No problem i thought. Batteries need to be replaced anyway. Put it on emergency power and it started up. Took it out and it seemed to run much better. Got up to 30 mph and was cruising along for about 20 min when port engine lost power. Back to barely getting up to 12mph and the port engine couldnt do above 2400 rpm. First thought was fuel. Pulled to the side. Switched fuel to run both engines off the starboard tank and took off again. It seemed a little better but still not good. Pulled up to my old marina to get gas and port engine died. Now it wouldn't even turn over. Pulled into an empty slip. Bought two new starter batteries and still the same. Waited for it to cool down and pulled the plugs. Ugh. One side had water in the pistons. Water in the oil. Sprayed a bunch of wd40 in the cylinders and then I ran a compression test.
Basically it looks like i came in on two cylinders. My reading of the numbers tell me i likely have a blown head gasket between #5 and #7. Worst case scenario is a cracked block. Best case is broken rings? Or am i missing something completely. I have a mechanic that can't get to it till next week at the earliest and i am going to see if there is anything i can do to help speed up the process. I am not sure if they are going to try and pull the heads on the boat or if they are going straight to pulling the engine. This sort of feels like the engine is coming out. What are everyone's thoughts? Start up an only fans page?
#8 40
#6 180
#4 140
#2 95
#7 0
#5 0
#3 30
#1 180
Any reason you don’t suspect risers/manifolds as the problem?
If you can have someone spin the engine over by hand while you use a long screw driver to verify the pistons are moving. Do this with all the spark plugs out. If they are not the engine is coming out.
If the pistons move then I'd pull the heads to see what's going on. I don't know if you're in fresh, salt or brackish water but if it's not fresh water that changes everything. If salt water got in the motor I'd be willing to bet they'd pull it. I don't have any experience with salt but it seems to do damage very quickly.
Since shops charge by the hour and efficiency is needed this time of year they may pull the motors anyway for a more thorough inspection. I'm pretty sure most marinas can yank a motor in an hour or less. The tear down is much easier on an engine stand rather than the endless treks up and down a ladder to the boat. And you don't have to worry about greasy finger and foot prints in the shop like you do a nice white rinker.
FYI, David is in brackish water, so not the best, but not the worst either. But it does sound like it may have been sitting a while. If the pistons move, you may have saved something spraying some wd40. Keep us updated.
But for more hp there is a chance you'd have to reprop to stay in your wot rpm range.
The good news is many report being on plane quicker and cruising rpms being lower after they add as little as 30 or 40 hp.
Being two engines, those parts add up quickly but we're all fast to give you upgrade ideas when we're not the ones paying for it!
Hope you can get her back to pushing water soon...
#8 160, #6 140, #4 170, #2 170, #7 185, #5 200, #3 165, #1 180. The cylinder #5 reading at 200 was weird. Even brand new it shouldn't be that high. The mechanic just said that it was strange but that he would just redo the compression test later after i had a chance to warm up the engine. The other cylinder at 140 was still within specs especially if you discount the 200 reading.
Assure your audience that dad's are allowed to make this joke.
