Painting props
davidbrooks
Member Posts: 1,418 ✭✭✭✭
ok so this thought might be considered sacrilege. Might even get me booted from the site. There are a lot of posts on cleaning SS props. However, I haven't found any from anyone professing the benefits of painting SS props with some form of antifouling paint. I am bottom painting and painting my out drives and the props were covered in barnacles. Does anyone paint their props? Does it help? Other than not having shiny props any reason not to?
You can use a couple of different products. Petit makes a product called Prop Coat Barnacle Barrier which is what I used this year. There is also a product called PropSpeed that is expensive but is supposed to work very well. I would spend some time googling to see what you would think would work best for your application.
Greenwich Bay, Rhode Island
The only prop finish that might stay put is PropSpeed, but it's pretty expensive (probably $250 per propeller).
I'm no where close to salt water but I'd try it before I'd pay 250 a prop.
I've had zero luck painting aluminum, chrome or stainless without adhesive promotor.
I checked the props this weekend and guess what...didn't matter, the barnacles are back again this year. So, the boat is getting short hauled today for a quick bath. I know I can certainly find a better place to spend $500+ but I guess it's gotta be done.
Granted, I haven't been able to run the boat as much as I would have liked to because the weather hasn't really cooperated in my area this year...but still.
